As far as I know, I'm ready to publish. I've looked through a few tutorials on more the design-based parts of RapidWaever, but nothing on publishing. I've already purchased my domain, and I'm just looking for either some help on getting it published, or some resources to look through.
I have not tried the and FTP upload yet, as I'd much rather just go through the 'Publish' option.
Thanks.
Comments
For example ...
FreeStack Theme
MacSupportCasts
{ old forum post count = 6128 }
Just my two cents,
Alan
I use godaddy.com and have had no problems with them.
Is this your sole website on your hosting account, or do you have more than one url that you're using?
Regardless, the first field (server) is the site you're uploading to.
The second (username) is either your godaddy customer number or user name.
The third (password) is your password.
The fourth field you only need to worry about if it's not the primary url you're uploading to. For instance, my main site is www.ariessun.com. I have another url at www.alchemyphotography.com. Aries Sun is my main one, Alchemy Photography is the secondary account, so I had to create a path with my hosting to differentiate the two. Alchemyphotography.com automatically routes to ariessun.com/alchemy. That's what the path field does. You probably don't have to worry about it.
Correct. I assumed there was maybe a waiting period prior to the site actually getting up. So far there's nothing though.
edit: It's "up" if you could cal it that. The site's a mess now.
Did you specify any paths or anything like that?
What's the url, if you don't mind me asking?
I only have one url, I specified a path as "index" because it didn't seem to work otherwise. The url is jacksclevername.com.
You need to download a 3rd party FTP client such as Cyberduck. Enter the settings as provided by GoDaddy and then you will be able to see your Host Directory.
Here is some info from GoDaddy - FTP How-To and Accessing.
FreeStack Theme
MacSupportCasts
Looks good. Try just using a slash for the path, see if that works.
As I mentioned, I spent two hours on the phone with their representative and he was basically no help because the site would not publish to the path they sent me. That is why I changed. Obviously from what I am reading from another person here and elsewhere in the forums, I am not the only person who's had issues publishing with Rapidweaver to Go Daddy.
I am not saying that GoDaddy is a bad service but my experience has soured me from using them because of the Rapidweaver publishing issues. Although I used Dreamweaver for years, I have grown especially fond of Rapidweaver and find that it is my first choice for producing sites. Hence the publishing issues with GoDaddy will keep me from recommending them to clients who I produce sites for.
Again, just my two cents and experience,
Alan
Just follow these instructions.
Log into your GoDaddy account at godaddy.com
In the left sidebar, click on "Hosting". This should take you to a list of your hosted accounts.
In the middle of the screen there should be a list of hosted accounts, or just the one if this is the only site you have.
Click on "Manage Account" - Another window will pop up, so make sure you are not blocking pop ups.
In the new Hosting Control Center window, click on settings.
Then click on manage FTP users. Create an FTP user and password. This is going to be different that your account username and password. You can create multiple FTP users for each hosted account.
Write the FTP username and password down so you don't forget. If sometime in the future you do forget, just go into this same panel and click reset password.
Now from RW go into publishing settings and under server type "ftp.yoursite.com"
Username is the FTP username you have setup
Password is the FTP user password you have set up
The default path is the root directory so leave blank
I hope that helps.
Anthony
http://www.studio1069.com
It should look like this:
am completely new at web design, hosting companies, domains & such. i found rapidweaver to be pretty easy to learn but very complete. no complaints with rapidweaver. my problem is that i signed up at godaddy for my domain & web hosting. they have alot of creative advertising to lure you in but their site is anything but user friendly. am looking for a new hosting service for my other web sites as godaddy lost me as a client in less than a week. would like some feed back, good or bad, on some decent hosting services out there.
thxs
The main site is: alwaysanadventurecharters.com The site I want to post to is: mysandiegoacupuncturist.com
So in that fourth field what would I type?
Thanks,
Tori
Thanks.[/quote]
The fourth field you only need to worry about if it's not the primary url you're uploading to. For instance, my main site is www.ariessun.com. I have another url at www.alchemyphotography.com. Aries Sun is my main one, Alchemy Photography is the secondary account, so I had to create a path with my hosting to differentiate the two. Alchemyphotography.com automatically routes to ariessun.com/alchemy. That's what the path field does. You probably don't have to worry about it.[/quote]
Server: your site name
Path: nothing if you have only one site
I've got /betting path because betting.gamblefaces.com is another site on main site gamblefaces.com
Good luck!
Any other ideas?
Thanks,
Tori
Did you put something in the field "User Name" ?
Thanks,
Tori
I didn't even thought about FTP
