Hi all,
I have converted a theme with a navbar on the side to the top however the bar does not feature when you go over the bar it automatically shows the submenus. I know it has nothing to do with styles css so I am wondering if there is another file that has to be included in order for the menus to work. If anyone could tell me what files to delete or include that would help. (I have changed the plist key RWSupportsToolbarRelTag to yes).
Thanks,
Jnani
