Realmac Software
Welcome to the RapidWeaver Community Forums, where you can chat with RapidWeaver users from around the world!
FreeStack Theme Help
I have a new site in test and i have an issue with the "more options.." on the recliner parts page and with the contacts page when you hit send. The issue seems to be with the page wrapper function. The "light boxes" hide behind the page when clicked on. How do i bring them to the front?
http://www.couchguard.com.au
Thanks,
p.s the site is in test and the social media icons and some links don't work!
1552 x 1109 - 146K
Comments
  • tsilvatsilva Posts: 276Members
    Not understanding the problem. The "options" within the e-commerce section of the Recliner Page appears to work.
    Not seeing any lightbox triggers.
    The contact page appears fine on my end.
    What button is triggering the lightbox, and which lightbox are you using? These can be a little persnickety.
    Best regards,
    tsilva
  • NewbieNewbie Posts: 16Members
    Thanks for replying. I'm not sure you understand what i mean. Hit "submit" on the contacts page. The little box (light box)appears under the page (behind everything) that says "oops! an error has occurred" the page should dull out and this box be visible clear on top of everything. Same is happening on the recliner parts page with the "more options" link
  • soonwaisoonwai Kuala LumpurPosts: 240Members
    Definitely a z-index problem. I'm not familiar with FreeStack so someone else will have to chime in here. Have you asked at the Freestack Google Group?
    https://groups.google.com/forum/?fromgroups#!forum/blueball-rapidweaver-themes-and-stacks
    Hi Soonwai,
    I just adjusted the z-index value in the navigation HUD and it seems to of fixed it! Thanks for pointing me in the right direction.
    Newbie
    No worries, mate. Great looking site by the way.
Leave a Comment
bolditalicunderlinestrikecodeimageurlquotespoiler
