Hi Guys
I am trying to insert some code into my website from sumome
I want it at the bottom of my page which is a stacks V2.x page with twitter fetcher and instagram on it.
Where do I put the code?
Many thanks
Hi Guys
Many thanks
Try putting it in an HTML stack. Bear in mind that themes using Javascript may clash with 3rd party widgets
@michaelbbeck
You can use a HTML stack, or even a plain text stack. With the plain text stack select the code and set “Ignore Formatting”.
Thanks for the support guys, I will give it a try.
How did it go?
It didn’t work for me.
you have to install the code in every page I assume.
