Humberto,
If you can’t even Force Quit, it suggests to me that there is something wrong outside of RW - perhaps in the OS itself? Good luck!
If you’re able to ZIP up the project file and send a download link (perhaps to a Dropbox file) to support at realmacsoftware dot com we can investigate further.
—Nik
Gracias Nik
I will do that.
I need an email address for the dropbox. I will open a folder for that matter.
Can you email me your at: [email redacted by forum moderator]?
Thanks for your help.
Humberto
Sunny Puerto Rico
Please could I ask you to simply generate a Dropbox Share URL (via the Right-click menu) instead and send that over? That way, more than one member of the team can retrieve the files easily instead of being tied to one person’s Dropbox?
Thanks!
—Nik
The link was sent to support, hope you get it right. Any help will be appreciated.
Humberto
Humberto,
Not wishing to push in, have you thought of obscuring your email address posted here now that it’s served its purpose: spammers love that kind of ‘invitation’? :-(((((
