Uneven Two-up columns in tablet view
http://massagetherapybypaul.com/page6/not.html
On this page of my website, the four column stack produces two uneven columns of text and pictures when viewed in tablet view or when I narrow the window on my computer to tablet width.
I don’t know how to fix this. The website is designed with the Henk Vrieselaar theme Stripped. Although I believe I have all the correct options selected (stacked columns for mobile and two-up columns for tablet) changing them did not fix my issue.
Hi Paul,
I’m not sure how to fix this problem, but I would be inclined to look at some ‘specialist’ column stacks that may give you better options and results. Select the Column category on StackCentral and you’ll find quite a few stacks listed that could help.
Marten
RapidWeaver Central
Have a look at Elixir’s Bricks 2 stack. That might do the job really nicely. http://elixirgraphics.com/previews/bricks-2/page1/
Thanks, guys for your suggestions. I am checking them out. I wish what I used would work, though! I am going to try another template just for the heck of it and see what happens. I won’t be changing my whole site, just testing out another template for curiosity’s sake!
