Using partials over several projects
Is it possible to use partials over several projects? E.g. I create a footer and want to use the same footer construction in another project. If it is possible, how can I do that?
Yes, you can either copy and paste the partial between projects or even drag pages containing the partial between projects.
Since Partials exist only in projects then a good idea is to keep a project just containing your favourite partials for future use.
Since this question appears in many threads, I’ve put the answer here: http://cafe.yourhead.com/?qa=112/is-there-way-to-use-partial-more-than-one-rapidweaver-project
