1/20/16 8:37:43.000 AM kernel[0]: Sandbox: RapidWeaver 6(1881) deny(1) forbidden-link-priv
I have a customer’s project that takes a very long time to launch. I am seeing several of the following logged to the console…
I am trying to see if this is directly related to Payloom.
Anyone know what this error message means? Maybe it will shed some light on where to start debugging at.
it means that some code somewhere is trying to access a URL outside of the sandbox.
if you have the file and can generate that error then you can test to see if it’s your plugin. you can just remove your plugin from the add ons folder and run the test again. if the error still shows up, then you know it’s not your plugin.
