Hi everyone:
It has been a few years since adding anything to my Rapid Weaver 7.( I am still a bit of a novice when using Rapid Weaver) When I go to see what is available as plug in’s and add on’s , everything says for Rapid Weaver 8. Do I have to upgrade to Rapid Weaver 8 in order to get any new add on’s now? And I am assuming I will have to purchase Rapid Weaver 8 as well in order to upgrade? Thanks for the help!
There are lots of themes that work with RW7 but there are some new features in RW8 that are worth the upgrade. I would just go ahead and pay for RW8 and Stacks 4 if it were me. Probably not the answer you wanted but it will be best down the road.
Parker- thanks for responding - It looks like upgrading may be what i have to do at this point.
Doug- really ? wow Ok thanks for this
A lot of addons should work with RW7.
Stacks 4 if you do have it would be worth it upgrade from 3.
