To create a link to another page in the project is straightforward using the “Set Link” dropdown, and selecting the desired project page (see screenshot).
However, I would like to add#filter=something to the end of the link.
For example, if the URL of the project page is:
www.domain.com/page-2
then I would like to ask RW to add the hash-tag to the end of the URL automatically; i.e. the link I want is:
www.domain.com/page-2/#filter=something
Now I know I could enter this as a URL directly via the Set Link dropdown. But, this has the disadvantage that if I subsequently republish the site at another domain (which will certainly happen as I publish an in-development site to a different address than the final version), then I have to manually correct every URL.
I would be grateful for any suggestions on how to more elegantly solve this problem!
Are you trying to send them to an anchor point on another page (#section2) i.e.
<div id=“section2”>Section2 of the page</div>
<a href="#section2">Jump to section 2</a>
Or, are you trying to pass HTML data? i.e.
< element data-*=" somevalue ">
If you need this same kind of info for email:
eMail HTML Stuff
Here’s how you do it.
We’ll use thescreensavers@techtv.com as our example email address.
• Subject field: To automatically fill in the subject field, add the code in red to the end of your email address in the mailto link.
Yes, this is what I am trying to do. In particular, I have a stack called Filter (from Yabdab) running on a page. If I call that page, but add the hash-tag #filter=cats to the page URL, then the Filter will automatically filter only those items tagged with cats.
also you can use relative urls… i.e. …/mypage
Great, thanks. I think that’s essentially what I need. To be clear, if the page called “Talks” is page 2 in the RW Pages list, I should use the relative URL
Did you try adding a custom data attribute to the page link?
In your image above, select the page, click the + to add a data attribute, add the name and value.
