Cart 3 Variable Button
Hi there. I’ve just bought Cart 3 which i am running on stacks 2 and RapidWeaver 5. The blue variable add button doesn’t appear meaning I can’t add variables such as size.Does anyone know how to overcome this problem. I’ve tried the forum and Bug report with Yuzool but I need a quick answer as under deadline to launch an online shop.
Many thanks
I’m guessing that is causing the problem. Cart 3 is relatively new and you are trying to run it on a release of RapidWeaver that’s three releases back, and a version of stacks that’s two releases old.
I’m pretty sure that you’ll need to upgrade both. The current releases are RW8 and Stacks 4.
Thanks Doug - I’ll try that
