Difficulty to publish modified text in a Foundry container
Hi, I just started a web site with RW8 stack & Foundry. Quite satisfied with the design, I modified few words in a container and publish.
The modification didn’t show on Safari. So I replaced the container, retyped the text and publish the whole site with no result. Anyone for help?
Hi Patrice and welcome to the Forum,
It always best if you can provide a URL for stuff like this. My guess is that you may be getting the results from the browser cache. So the changes are being published, but you might not see them.
If you have the developer tools turned on in Safari(Preferences > Advanced > Show Develop Menu in menu bar) You should try to empty the cache(⌥Opt+⌘ Cmd+E) or try with a differnet browser.
Also, if you added anything to the page since your last publish that requires PHP, like a form or Alloy Embed – you might have an index.html and an index.php file in the folder for that page. The index.html file will get served up before the newer index.php file. Not saying this is 100% your problem, just something else to check.
Thanks to Doug & Adam. I emptied the cache, used an other browser… unsuccessfully. The text to be modify is in a paragraph.
<span style="font-size:14px; color:#000000;">&ldquo;Les Fr&egrave;res de la C&ocirc;te&rdquo;? A Li&egrave;ge?<br />Oui. Des passionn&eacute;s unis en une confr&eacute;rie par un m&ecirc;me amour de la mer et plus particuli&egrave;rement de la navigation &agrave; voile. Une confr&eacute;rie bas&eacute;e sur l&rsquo;entraide, la solidarit&eacute;, l&rsquo;hospitalit&eacute; &agrave; l&rsquo;instar des flibustiers des XVIe et XVIIe si&egrave;cles. Les coutumes de ces flibustiers, contrairement aux habitudes des pirates et forbans, impliquaient discipline, tol&eacute;rance et solidarit&eacute;.<br /><br />Dictionnaire Littr&eacute;:<br />Confr&eacute;rie: XVIe si&egrave;cle - Montaigne.<br />&ldquo;</span><span style="font-size:14px; color:#000000;"><em>C&rsquo;est multiplier en confrairie la chose la plus une et unie (amiti&eacute;), et de quoy une seule et encore la plus rare &agrave; trouver au monde</em></span><span style="font-size:14px; color:#000000;">&rdquo;.<br /><br /></span>
I wanted to add "des Antilles". (site URL: freresdelacote.org) - Server blocked tonight because of ftp settings errors with dreamweaver.
Give us a link please to the page. Also give us a screenshot of what you’re seeing in preview mode and what you’re seeing in the browser.
Not sure what you mean by this?
Adam(@Elixir) I think this is the site: https://www.freresdelacote.org/
@Patrice is the change you made on the home page?
When did you make the change?
The Home page shows a last change date yesterday(Sun, 06 Dec 2020 16:01:30 GMT), is that rwhen you tried the change?
I don’t know what it is that you changed.
Hi everyone,
Thanks for your messages. Sorry being late (returned home 1H ago).
Nothing wrong with RW. I went to the host’s folders and found two “index.html” of the main page at two different levels. One with (upper) and he other without the modified text (lower level: “www”). This has been rectify.
Thanks for your help.
Very sorry for the inconvenience.
Screen shot of the text modification:
