this was the same way not as brain ache, ill post the mobile version I have multiple attempts at the mobile the version I think is the most easy, no idea if this how it is supposed to be done
I have the upload amplify issue with the cloud, once working will upload
not sure need this now at the options for screen widths and mobile added to Elements, unless I wanted a more fancy layout, can now combine with hidden and visible etc
restarted still cant upload to cloud
cannot upload to cloud, message - cant upload {amplify..
restarted Elements
signed in and out
restarted mac
still cant upload
**update
ok worked out why I couldn’t upload I had + in the file name
This is my first ish version uses scale-y-95, I have other versions that do this a different way now and add different effects
this gave me a headache most time ever spent on a component, trial and error, + not finished, no way near finished but kind of shows the layout I took
so for interest only
Thank you. That gives me an understanding of how the basic part is done. It is greatly appreciated.
Any chance for a “Top Pages +” component that allows for subfolders / multi-level navigation??
It would make my life SO much easier!!
Hmmm, like a vertical tree navigation component? ![]()
Doesn’t actually need to be that complicated (although additional components are always welcomed). The top pages component works for what I want, EXCEPT it doesn’t do sub-folders / multi level. If you duplicated top pages, and added that capability, that would work for what I need.
My dropdown menu requirements have 15-20 links in each of them (all different) and it is a royal pain to do it manually as it exists now.
Okay, got it. I’ll have a chat with @ben and see if we can work something out…
Any update on this sir??
We have a vertical menu component in the works, can’t say when it’ll ship though… ![]()
