Easy CMS gurus ( esp @zeebe & @joeworkman ) - hope you can please help.
I want to centre a line of text within an Easy CMS text stack.
As the Easy CMS text ‘editor’ toolbar does not contain a centering button I am guessing that this needs to be done via Markdown.
Thus far I’ve been unable to find a way to do it so would be glad of some guidance please.
Thanks @dylan - I see the alignment setting, have switched it on and have republished the admin page to the server. However there doesn’t appear to be any difference to the editor toolbar from before. Is there something else I should do?
Many thanks.
It should show up within the actual edit text stack like in the screenshot. Make sure you have hipwig editor selected in the text admin stack. Also if you have SSL enabled sometimes it takes a bit longer for edits to show.
