FIXED: load behavior from Yuzool Navigation stack
Thanks for looking into this @yuzool.
Another thing I noticed, in the Navigation stack settings, if you select: Layout/Fill Mode/Fixed Size, it seems to break the burger menu. Maybe you should take a look at that.
First things first!
I’m just going to send you a BETA to test re: the speed bug - please try it with this setting:
I will DM message you the BETA now.
Yes because it’s a responsive menu. So please use fill or flexible. If you want to restrict the width of the menu items please use the Fixed Inner Width or Fixed Centralised options… depending on what you want to achieve?
43%402x
16%402x
If you are trying to achieve something else please let me know but your demo (The Crucible of Transmutation) seems to centre nicely already
Thanks for trying out a fix Michael. Implementing a load delay seems to be a little better. However, it still causes a content shift, which was my original objection. Although certainly a much smaller shift, now just the height of the navbar. Is there not a way to do what many image containers do, where they reserve their space on the page while downloading? I would think that would solve the whole issue, rather than delay the loading.
Thanks Joel for testing this out!
Let’s chat about this and fine tune it for release in coming days :slight_smile:
Hi Michael,
There was another problem with the beta update, which I did not notice at first. The drop-down menu appeared on the left side of my site, instead of below the parent page on the bar. Oh well.
I really appreciate your efforts to fix my issue. However, I decided to just continue using the Top Bar stack that comes with Foundation. It has been working fine for me even though it does not have as many options for customization. I got Navigation for half-off during the holidays, so not a big deal really. It’s all good.
Thanks,
Joel
Thanks Joel - I see this and will be fixed in an update soon with a few more things :slight_smile: Thanks for working with me on this!
This is now fixed @Mysterion and 1.3.7 released just now :slight_smile:
It required a little lazy loading - below is Chrome and it should appear one time on your site (or future sites) also!
chrome-loading
—> This is fixed also
And other things include a nice feature request by Luke - the background on mobile can be styled a different colour so it doesn’t clash with transparent desktop backgrounds:
Thanks for all the help everyone. Updates now ready within RapidWeaver, sent via email and attached for Bundle users.
Here’s the full run down:
Navigation Stack 1.3.7
NEW
  • Added a LazyLoading option to load whole Navigation later so that it no longer loads the menu first on slow connections or Chrome. Thanks @mysterion
  • Added a delay animation option in seconds to the fadein option so can be adjusted and tested
  • Option to add a solid colour on mobile menu, even if desktop is transparent - thanks Luke for this idea
FIX
Happy Navigation Weaving! :star_struck:
@yuzool This new version is not showing up for me as an update when RW checks for new stacks.
@Mathew - thanks - did you get the email with the download link?
What version are you running?
It seems people are downloading it from the logs so not sure why it’s not working… I’ll DM you a copy now too
@yuzool, I still have 1.3.0 installed and it’s not showing any updates in RW. It was bought by itself (not bundle) and I have not gotten an email. Not sure if on0bundle users were sent and email.
Just resent it to you now @DLH
It should have been sent out to everyone.
The email provider / cart fulfilment is by Selz and they are looking at the emails too just in case.
FYI, I fixed this now also in the Navigation Stack available in the Pulse 5 integration.
Thanks, Michael.
I did get the link you resent. Btw, I do get your emails with new product announcements. I just never got an initial email about the update to Navigation with a download link.
Since I bought Navigation, I’ve been getting my updates through RW. I did noticed when I unzipped the 1.3.7 version from the download link that the file date is Nov 11, 2011. RW warned that it was older than the version (1.3.0) already installed. I told it to reinstall anyway and now see 1.3.7 in RW. Perhaps the creation/modification date being wrong is causing issues with the built-in autoupdate.
Anyway, thanks again for the great service and a wonderful stack.
Thanks @DLH - the emails I sent out go via 2 servers and think one of them is having issues, but glad you have it :slight_smile:
Interesting about the dates, will investigate. That could be why auto updates suddenly stopped. Thanks.
Appreciate that :heart_eyes:
Navigation Stack now updated to 1.3.8 and should update from within RW as the date has been modified via the Terminal. Thanks @dave for the alignment feature suggestion.
Here’s the run through!
(emails sent out also to all users as well…)
IMPROVEMENTS
  • Allow for alignment of text of dropdown (left, right, centre)
    This is independent from dropdown and parent alignment
FIXES
  • Shows today’s date as last date to modify the Stack so this should help with updating from within RapidWeaver
THANK YOU, Michael! I love the way you are open to new ideas that can enhance your products. As you can see here, my site’s navigation is now centered, but the dropdown are flush left. Much, much nicer than everything being centered.
All the best! Dave
Not seeing the 1.3.8 update in RW.
I first saw your email (about 1.3.8)…then tried to update via RW. It didn’t work so I used the link in your email???
Same here.
@DLH @drsdayton @thang - please use the link in the email. If it says “do you want to update?” just click “yes”
From now on (after 1.3.8) updates will work inside RW as the date has been modified in the file
Thanks @dave for all the great suggestions :slight_smile:
