[Help] Successfully Uploaded Files But Website Isn't Loading
I have successfully uploaded all the files onto my ftp server. However, when i try to connect to it, it provides me with the following error:
This site can’t be reached
www.WEBSITENAME.com ’s server IP address could not be found.
How can i fix this? I can connect to my SFTP server…
Thanks!
The simplest reason I can think of is uploading site files to a wrong directory. Are you sure your files reside inside public_html, or similar folder on your server? If in doubt, get in touch with your ISP.
That sounds more like a DNS issue. Did you register your domain at the same place you host at?
Not sure why you didn’t give the true URL.
