Help! This widget provides an audio player for your stream tha
Just dug out RW 5.1. and want to do a little audio streaming,via shoutcast.They give me codes for web player widget to insert onto a page, but i dont know how to insert code onto the page or how…Can some one please advise.Thanks.
This widget provides an audio player for your stream that can be embedded in a web page.
Place the following code on your web page wherever you would like the widget to appear:
<div…div.>
then
Place the following code at the bottom of the web page, just before your tag:
<script language..........
if its a stacks page, just put an html stack where you want the player and paste the code there,
put the javascript in the javascript area in the page inspector
Thank you.The silliest question is the one never asked,so i will ask.
Where is the javascript area in the page inspector.Thanks.
@faustus
Did it work? I’m going through the same issue.
This topic was automatically closed after 3 days. New replies are no longer allowed.
