Help with plugins
Hi , someone knows what plugin/theme I can use to recreate this website : https://agroyans.com/
I assume your asking about the anim oh the home page and not the product catalog on the other ones.
You won’t find or even be able to do that with a theme, you could create something similar to the anims with the BigWhiteDuck SectionsPro / SectionsBox stacks but it would be a lot of work.
It almost definitely a completely custom setup written specifically for that site, if you really want to peruse something like it you’ll need to become really good friends with Tumult Hype https://tumult.com/hype/
thanks!! I will try Tumult
