How do I reclaim my website?
About a year ago my dog knocked some tea onto my computer and destroyed it. Now I can 't add to my site. I am not very good at this sort of thing but I remember years ago using front page, they had a feature where you could download a sight from the web. I want to download my site to my computer so I can add to it.
Any ideas would be appreciated
Art
You can’t change it with RW without the project file.
WebSnapperPro or SiteSucker would allow you to download the files to your computer but as Scott said, without a project file from RW you wouldn’t be able to do anything…and Front Page is a bit different and outdated I’d say… (2003)… :slight_smile:
Guess your best bet is to download the files from your website and start all over using RW
what is a project file? I had my info recovered but I have trouble finding it.
That’s the RW file that was created when you built your site.
Depending in what version of RW you used to build it, it would have a deferent extension. It could be your project name.rw or .rw6
Can you give any more info? Did you have a backup of your computer?
