How to create side to side backgrounds
I’m usine Voyager Pro. They use Extra Content to create specific areas on a page with backgrounds. I would like to create other areas with backgrounds that go from side to side. How can I do this without using Extra Content.
I’m not sure as I don’t use that theme, but you might get some help over at the Elixir forum. Elixir/Adam made Voyager Pro.
That isn’t a feature of the theme. The main content is in an enclosed container. The ExtraContent areas you’re referring to fall outside of that main content area.
Ok, I had to get a little creative to differentiate those areas.
