I have been having redirect problems for a few months. Came across a website that analysed my home page today and it came up with the following under minimise redirects asking me to remove
Could you be a bit more specific on what problem you’re trying to resolve with redirects? Also what tool (website you came across) are you using?
The file you listed above appears to be the font awesome web fonts file used by some of your stacks. Fontawesome appears to be working okay on your site, and I’m not sure why this would get flagged as a redirect error.
I am clutching at straws trying to solve a too many redirects problem at www.antiquemaps.com It appears to be worse with Safari so I am using Chrome now to look at my own website. Although when using chrome sometimes you can see a redirection fault page for a tenth of a second before the page appears. Just trying now browser Brave has come up with www.antiquemaps.com redirected too many times
I have asked my hosting company Easyspace many times to help. There last reply was
There may be plugins that you have active that will be causing this. You would have to disable these in order for the redirect to go through normally.
If you enter my site by going in from another of the many pages the error does not happen but if you stray to the home page a number of times it will happen.
@swilliam Thanks Scott. I will certainly do a mark an all pages and export. When you said this line is causing an error in Safari, which line did you mean. Sorry I am not into the code of .htaccess files
@swilliam Export in progress, just another 2160 files to go. No idea about that line. But will delete it when I have control again and report back to you.
