Looking for a path to allow visitors to my site to vote on their favorite image
Good day all~. Any thoughts on this request and/or where to look? Nothing fancy, just a simple vote count based on 20x images. Appreciate any assistance you can give. Cheers
Hi @mzscapes,
What page type are you using to display your photographs? There are some stacks out there for giving likes that might work if you are using a stacks photo gallery. Not sure if there are any advanced voting stacks out there that can give more metrics/stats. What kind of voting features are you looking for?
Hi Dan~. Many thanks for responding. Thinking that a stack with likes will do the trick. Want to be able to track the images by vote or like and then re-sort by hi to low (manually most likely).
Your recommendation. I use a combination of galleries :: Montage 2, Light page base, Image gallery (CosCulture).
Cheers…
mark zborowski
May our paths and errands meet - JRR Tolkien
The power of imagination makes us infinite - John Muir
There is nothing worse than a sharp image of a fuzzy concept - Ansel Adams
No problem.
A few stacks I found that might work:
Rating stack by @willwood
Rate It stack by @Doobox
Love It stack by @Doobox
There might be some more I’m missing, but the above are some good ones to check out.
Hi @mzscapes
I have sent you a private message with some details and screenshots of new plugins I am developing.
Based on what you describe you want, I think one of these plugins might tick all the boxes (no pun intended), in regards to voting.
:slightly_smiling_face:
