Manually check for theme updates
I thought that th Check For Updates in th RapidWeaver manu used to trigger an update check for themes and plugins. It does not seem to do that anymore. Is there a way to manually trigger that check? Or do you just restart RW?
Seems to do it here. I did a “Check For Updates…” just now and got a message about a theme update that was available.
I think I might be behind on the betas though as I’ve been busy recently. I’m on on build 20541b right now.
46%20PM
Thanks. I see my problem now. Its in my update PHP server.
@dan is there anyway to add the name of the theme to the sparkle GET parameters? You are sending along the version information already. But the name of the theme would be awesome.
