Also deleted it completely and started a new one. Same issue.
items do not re - appear
this is strange, Iām not 100% sure what the issue is. I did find some code in the template the needed tidying up though.
Iāve just pushed another update to Marquee Pro to the store, could you update to the latest and let me know if that fixes the issue? Thanks!
But the responsive items not working. I have set 1 on mobile and two on the rest but it doesn“t show only one on mobile.
Weāre working on this issue now and will ship an update to Marquee Pro shortly ![]()
Thanx Guys!!!
Goodnight from Peoria IL 7:02 AM here - time to sleep⦠LOL ![]()
New Marquee Pro build is up with the fix, please update via the store and let us know how you get on ![]()
The reason I was using a container was so it could handle the hover effects, as well as the link.
can you add links to the images in marquee?
Yes adds links fine!
I think Ive got it but not when adding a folder! THANKS
That is correct.
