Lucas
(Lucas Tsolakian)
6 May 2016 17:17
1
With Renew I’m introducing Premium Projects for UIkit Framework:
Renew comes in two flavours: Services and Shop, the latter requires Rapidcart Pro and Pluskit plugins.
Premium Projects also include all images so you will receive a ready-to-use pro-level RapidWeaver project, just customize it for your needs and you’re ready to go.
Check the Projects page here:
Updated March 2020 ✓ At Archetypon we create interactive, eye-catching, contemporary themes for the RapidWeaver web design platform. We also make innovative stacks for Stacks plugin and creative brics for the Blocs application.
WDA
(Wolf Ademeit)
7 May 2016 15:45
2
What version of RapidCart Pro did you used? I have 4.6.3 installed but it ask for a newer version!
Lucas
(Lucas Tsolakian)
7 May 2016 16:09
3
Hi @WDA , I’m using 4.7.0 in this project. I’m not sure if you have to update via RapidWeaver or otherwise, I’ll ask Roberto (RCP developer) about this one.
WDA
(Wolf Ademeit)
7 May 2016 16:12
4
Hi @Lucas I tried autoupdate again - 4.6.3 is the lasted version available via RW…
Lucas
(Lucas Tsolakian)
7 May 2016 16:34
5
It ends up that I’m using a beta version not publicly released. @gibo was kind enough to send me that version so I may share it, but as it is a beta version please backup your projects before using:
https://tls.4gnd.com/rw/rapidcartpro/download/beta/RapidCartPro47Beta.dmg
gibo
(Gilberto De Faveri)
7 May 2016 16:45
6
Please report any issues with this beta at http://help.4gnd.com
Turtle
(Brad Halstead)
8 May 2016 01:38
7
Hadn’t even gotten that far @Lucas , thanks @gibo for the beta for functionality
Does look nice though, both of you!
Brad
