One project won't open, one won't publish, one is fine... What?
(Ben Balser) #1
I am trying to publish updates to sites since moving to a new computer. One project won’t open at all. One opens and publishes fine. The third when I go to publish, gives me this, and it never goes away or uploads the pages.
Same version of RW, the operating system, just a new computer. So why am I getting all of this malfunctioning? It’s almost as if RW is becoming so unstable I can’t use it. Any one have a clue? How do I get RW back on track?
(Ric) #2
Have you tried trashing your ftp details and entering them afresh?
I had to do this after ‘upgrading’ to High Sierra’ recently.
(Ben Balser) #3
You mean a prefs file somewhere, or delete and recreate inside the app’s Publishing settings?
(Ric) #4
Simply inside RW’s publishing settings.
(Ben Balser) #5
Nope, that doesn’t work. What next?
(Doug Bennett) #6
Have you tried reinstalling RW? Seems like your having a lot of problems that most of us don’t.
As for publishing problems might want to take a look here:
https://realmacsoftware.freshdesk.com/support/solutions/articles/36000001207-how-to-fix-ftp-publishing-issues
(Ben Balser) #7
This is a site that worked just fine for over a year, before he High Sierra update. Once I updated, it published ONCE just fine, then gave me this issue. May try reinstalling and see what happens.
(Ben Balser) #8
Nope, reinstalling didn’t work.
(Doug Bennett) #9
I haven’t upgraded yet.
If publishing is the only issue left, then have you tried to publish to a local folder?
Just trying to narrow down the problem area. If the local folder works than until you get publishing within RW going, you could use a separate FTP client.
(Aaron Marquez) #10
@benb can you send me your project file and support logs?
Go to RapidWeaver > Preferences > Publishing and make sure “upload logging” is enabled.
Now, go to View > Clear Support Logs, then try to publish again. Now that errors have been generated, go to View > Copy Support Logs and send those over in a text file.
Send those over to support@realmacsoftware.com
Hope to get this resolved for you ASAP :slight_smile:
@jabostick and @teefers scared me away from the blur :stuck_out_tongue:
Are we considering RW 7.5.5 "it"?
(Ben Balser) #11
Wow, great advice quickly! Thanks!
teeters; same problem when exporting to a folder.
Aaron; I see no option to Clear Support Logs. Oh, wait, I found it, under the Help menu. Email just sent.
(system) #12
