Rapid Weaver Very Slow
Recently Rapid Weaver has become unbearably slow, wit the spinning beach ball appearing when I try to do any activity within the program. I searched this forum and did not find any solutions?
Can anyone help???
You might get more of a response if you post your RW version and any other details you have :slight_smile:
I assume you’ve tried restarting RW and your computer? You don’t have too many other programs opening that’s tying up your RAM?
Thanks for hint:
Using RW 7.2.2 with Yuzoolthemes (Box Stack)
Restarted, rebuilt permissions, have tons of RAM
Created a test site and I’m thinking it may be the ā€˜Box’ stack from Yuzool
I suppose if everything is ok without the Stack, then that’s your answer and I’d reach out to @yuzool :slight_smile:
How big is your project @drrjv? You can send it to use also to take a look but we’ve not seen this issue with Box Stack before.
If you have lots of images on the page and a heavy RW project file size - it could be recommended to try the ā€œWarehouseā€ option inside the Stack… :slight_smile:
The project is about 106 MB
Here is the site: nancyvaripapa.com
I created a small website without Box and it seemed to work fine.
I then created a new site with Box and it again slowed down considerably (not to the extent of the nancyvaripapa.com site.)
