RapidWeaver 7.2 Beta 5 (18457b) is now avaiable. If you’ve been experiancing a crash on export/publish then this is the build for you.
This is a beta release of RapidWeaver, do not install this unless you are comfortable with using pre-release software. Please backup all of your project before using.
Check for updates if you’re already running a beta build or directly download it from here:
[REMOVED]
What’s New in this beta?
Fixed a pesky crash that sometimes happened on export/ publish.
Happy Monday!
Cheers
Dan
UPDATE: 13th December
RapidWeaver 7.2 Beta 6 (18463b)
Fixed an issue with control-clicking on themes in the rewritten theme picker
Fixed an issue with the %banner_path% macro outputting incorrect resource paths
Thanks for the update.
This latest beta (v5) hasn’t fixed the inability to Control Click on a theme to pull up the contextual menu.
I’m assuming this problem is not occurring on your Mac on anyone else’s or it would have been more widely reported so I’m wondering if it is only on my Mac?
My only solution is go back to v7.1.7 unless you can offer a workaround?
This beta hasn’t fix my blog publish problem. RW still exports and publish all files, again and again!
I have 3 projects with Blog/Podcast pages. Two of them working fine, only exporting und publishing the changes. The differenz is that the project with the problems starts with the Blogpage. In the two working projects the blogpage is the second page behind the Startpage. May be RW has problems when the blogpage is the startpage?
Hi. It starts with El Capitan (Beta 3 did not) but the “Save as…” command of a freshly imported 7.0.4 project still brings a long term rotating ball and freezes the application.
“Save” and “Save as” commands of 7.1.7 projects work.
Another issue introduced (probably) with 7.1 is that RWML (tsooj stack) is not working anymore and the Armadillo Stack appears not able to work properly with the CSS from the main theme. These latter could be stacks related problems rather than RW related problems.
Can you send us the project that is re-publishing all files every time? Send it to: support@realmacsoftware.com and put the subject as ATTN: Dan (also link back to this thread and include your forum name).
@sandokandrea can you send us the project with details of the issue. Send it to: support@realmacsoftware.com and put the subject as ATTN: Dan (also link back to this thread and include your forum name).
@dan I’m happy to report that control clicking a theme is back up and running!
Thanks for fixing that.
You mention about rebuilding the Theme Drawer in the 7.2 beta, is this just behind the scenes engineering or is there anything visually different about it?
