Updated to this release version and republished a site from scratch after deleting all files at hosting service. Resources are not all uploading as they should. No link problems indicated… all appears to publish just fine. Some of the files simply do not get put in resources folder at hosting service. All worked fine with 8.03
UPDATE: Solved my problem myself… I needed to remove spaces from my resource names and republish. All works fine now…
Lesson to be learned: The name of a file that is fine for macOS might not be fine as the name of a file to be uploaded as resource. Earlier versions of RapidWeaver 8 would automatically replace spaces in a file name with hyphens so all would upload fine. RapidWeaver 8.1 does not automatically put these hyphens in for you. Nor does it let you know there’s something wrong in trying to publish this resource that has an improper name.
