RapidWeaver 8.8.4 on Monterey with PHP 7.4.21
Quick update…
We’re working on a new build of RapidWeaver 8 that will include PHP 7.4.21 and run on Monterey (ARM & Intel). This will fix the preview issues users are having.
FYI: Big Sur shipped with PHP 7.3.24, but I know in the past some developers have requested a newer version of PHP to ship with RW. Hence why we plan to ship with 7.4.21 (the last build on the 7.x branch)
In RW 9 we’ll include an advance option to specify your own install/version of PHP should you wish.
@joeworkman I know your hot on your php stuff so let me know if that all sounds good to you.
We should have a beta build out later this week for testing.
Happy Weaving!
Dan
Very very nice! :tada:
Cool :sunglasses: :fire:
Boom! We just posted a public beta in the main forum!
Will the new PHP server logic also be active on Big Sur (as I don’t have Monterey installed)?
Yup, it’ll be used in RapidWeaver under Big Sur too :slight_smile:
Some users reported issues with 8.9 and can only see blank pages. Going back to 8.8 or 8.7 fixes this. @dan Can you please check this?
On it! RapidWeaver 8.9 broken preview - Help!
file_get_contents() is disabled if anyone else uses that in Preview mode.
Blank pages also mean 500 errors and display_errors is disabled.
@yabdab Should be all fixed in 8.9.1 :slight_smile:
Let us know if you hit any other issues.
@dan getting reports that file_get_contents() is still not enabled in 8.9.1
Oh noes! Have you reproduced this or got a project file we can take a look at?
file_get_content exists, but something in this PHP build prevents it from returning data.
Just create a HTML page and use this…
<?php
echo $vcheck = file_get_contents('https://www.yabdab.com/yabcasts/fs3/version.php?v=3.0.6');
Doh! We’ll take another look.
Why don’t you use curl for that? file_get_contents is blocked for HTTP requests by default in many default configs.
Hey @yabdab we’ve looked into this some more, and we think it’s actually a recent change in PHP that is causing you issues. We’re pretty sure PHP has started doing peer validation when accessing https via file_get_contents.
Remember we moved from PHP 7.3.24 to PHP 7.4.21.
Take a look at this article for an example:
https://f-h-ferreira.medium.com/file-get-contents-ssl-operation-failed-php-4297ad92977f
Hope that’s all good. If you need more help on this I’ll refer you to my main man @tpbradley :wink:
Dan
@yabdab ah-ha! @tpbradley has just given me this code snippet to pass on to you. How’s that for service? :wink:
$arrContextOptions=array(
    "ssl"=>array(
        "verify_peer"=>false,
        "verify_peer_name"=>false,
$content = file_get_contents('https://www.yabdab.com/yabcasts/fs3/version.php?v=3.0.6', false, stream_context_create($arrContextOptions));
echo $content;
