Rapidweaver Turkish Language Problem
I am using RW 7. When I add description and keywords meta tag , there are problem about Turkish Character (ş,i,ü,ö,ğ) in html file.
What should I do?
This might help http://turkishbasics.com/resources/turkish-characters-html-codes.php
I can remember someone having similar problems some years ago. You may need to ensure that the font you are using on your website, whether it is embedded or a standard font, is a proper unicode font with all the necessary characters for Turkish. The standard fonts, such as Times, Helvetica and Palatino which are available on Macs and Windows PCs should be fine but there are probably many fonts out there that don’t support Turkish.
