Would it be possible to have the application remember the UI for saved projects?
Every time I open a saved project I have to drag the left window pane to the right so that I can actually read the titles of the pages. Then I need to open the pane for Stacks, which is closed by default. Then hit the button that opens the pane for the Inspector… Not a tremendous amount of work, but very annoying.
It just seems like this sort of thing could be saved in a preferences file somehow, so that it remembers it from the last use?
