Some time ago I re-built my site using stacks. In my files on server I see I have a mixture of old blocks files as well as the stakes files. Would be OK to remove the blocks files?
If they’re not being referenced anywhere on the site any more, that should be fine.
Many thanks Rob-can it improve loading speed by any chance?
All the best John
www.johnspringate.com
Probably not. If those elements aren’t being used as part of the site any more then they’re not being ‘called’ so their absence won’t improve site speed. There are other things you can do though - is there a particular page that’s slow or just a general sluggishness to the site?
Hi Rob The speed of the site is fine. Just wondered if removing unwanted files would enhance the speed
Pretty sure it won’t. Will obviously save you a tad of space but it’s been so long since I used Blocks that I can’t remember how much disk space the pages used.
Rob
Strange how blocks now seems to be ancient history lol
All the best John
