Resources reload again and again
How is it possible that I several times all my sesources have to reload again?
Is there a possibility that when I’ve done there ONE through my export map the rest will load automaticaly?
Please give me some advice
just flagging @dan in case he missed this one. :smiley:
Dear Isaiah,
You mean I remove all the items from the resource map and put all the items in my export map into the resource, do you think thay come direct on theit place? or do I have to check each one?
Regards Henk
I’m afraid I do not have any advice for you. I do not understand these resource errors any better than you do. I flagged @dan because it seemed like this thread might have been overlooked.
If no one replies further you should contact Realmac support.
