RW stuck in plugin update process
When RapidWeaver is set to automatically open last project at start, if it’s not running and you double click on a plugin to update it, you can’t complete the action.
Once you click “Install” you need to force quit the app.
Steps to reproduce the problem:
  1. Open a RW project
  2. Quit RW so the project will open automatically next time
  3. Double click a plugin to install
  4. Click on “Install” button
I think the problem is related to the “Loading Project.rw” window in background that doesn’t disappear even if the project is actually loaded.
Thanks @rob. I’ve managed to replicate it here too.
