HGBM
(Hans Georg Britz-Mauch)
1
I updated the Aptenon theme from Seydesign. There are a lot of new parameters, but I can not find the option to color the sidebar.
I use the @import-command using PlusKit so I also tried a background color of the page I import, but that also does not work.
Any ideas?
Thanks a lot for your help!
Hansjoerg
I do not see any option, either. You have to call Seydesign to get a CSS code to color the sidebar background…
teefers
(Doug Bennett)
3
Don’t have that theme, but looking at the live demo might want to try:
#sidebarWrapper {
background: #0000ff;
#sidebarTitle h3 {
color: #fff;
#sidebar {
color: #fff;
A URL when asking for help with CSS would be helpful.
HGBM
4
Hi Doug,
thank you.
Here are the links:
http://bip-freiburg.de/
http://bip-freiburg.de/beta/
The code seems to work, but the text is exactly on the edge.
Can you tell me how to insert a padding command in the css?
Thank you°
teefers
(Doug Bennett)
5
If you are talking the sidebar padding try:
#sidebar {
padding-top: 2rem;
padding-right: 2rem;
padding-bottom: 2rem;
padding-left: 2rem;
You can play with the values.
HGBM
6
Hi Doug,
thank you, but don’t work in RW.
See here:
teefers
(Doug Bennett)
7
Was looking at the old URL try changing the top line
#sidebar {
to:
#sidebarContent {
HGBM
8
Thank you – works fine now!
ptr
(Pietro)
9
in this post i answered Aptenon theme, banner not responsive?
You can use extra content 9 or 10 and customizes it
