Has anyone else received a too many redirects error when logging into Sitelok with Auto Login enabled?
I plan to file a bug report but want to see if I’m not alone first.
Brandon: I did have this problem about 3 years ago, but I can’t find what “solved” it. However, I know Adrian at Vibralogix helped out a lot.
This is likely unrelated but for a long time I put all the special Sitelok code in one snippet. For some problems that was the cause. Now I put one code snippet in the Prefix area:
<?php
$groupswithaccess="group name";
require_once("relevant-code/sitelokpw.php");
And another code snippet in the Head area for Disqus (if you use the Disqus plugin):
<?php if (function_exists('sl_disqus')) sl_disqus(); ?>
My guess is what I’m doing won’t help and you’ll need to contact Adrian.
I just ran a test @BrandonCorlett with the latest version and worked fine here so might be something specific in your setup. Am sure Adrian can point you in the right direction.
Thanks @yuzool, I had a feeling it was my setup. I’m leaning towards thinking it may be related to using CloudFlare. I’ll hop over end shoot an email to Adrian.
Ah… CloudFlare is often a trouble maker so good to suspect it
See what Adrian says and good luck with the project!
