Sitemap.xml wrongly generated
Hi Dan,
I have tidy website links enabled:
The sitemap unfortunately contains the full path to the index.php
34
The links inside the HTML markup is generated correctly, eg:
<li><a href="gallerystack/" rel="" class="nav_item">Gallery</a></li>
This will lead to errors in the Google Search Engine Console:
Could you please omit the index.php from the sitemap.xml ?
Cheers
Jannis
@dan Already on holidays? :slight_smile:
I think this issue has been raised before and it’s a problem with the framework we’re using.
I’d suggest turning it off for now as I can’t say when this will be fixed. Sorry!
Cheers
Dan
