Sites using sections
Can anyone recommend a site or two using sections please - just for inspiration in its use?
Many thanks
Gordon
Here you go:
Gallery usage of sections:
http://www.jochenabitz.de/shop/iceland/gallery/
and
http://www.jochenabitz.de/shop/boutique/
Everything I do uses Sections. Sometimes Sections inside Sections inside Sections.
Have a look at www.webdeersign.com and the Templates at www.webdeersign.com/templates and also Projects at www.webdeersign.com/projects
Many thanks gentlemen - plenty to go at there.
One quick follow-up question and then I can start work.
What size and resolution would you make a full screen background image please?
I’m assuming .jpeg images would suffice.
Somewhere between 1400 and 2000px across, pick a couple of your images and do some tests to measure quality/size.
have a look at xnconvert it’s very good at batch resizing images.
Many thanks Paul.
That lot will keep me busy for a week or two.
All the best
Gordon
20 seconds to load nqca.eu and 30 seconds to load the employability sites. I wonder what the problems are Paul?
Both loaded in a couple of seconds for me.
