Split Theme - slideshow on the background?
Hey guys,
is it possible to make a slideshow on the background?
Hey @mufflern - yes sure it’s possible :smile:
The theme as it is though, doesn’t have that capability but using some CSS you could animate the images. That would make an interesting update.
Thanks for the idea and let me know if you find a way ti implement this
Hey! I am a really beginner…Can u tell me how it will work?
Greetings from Austria!
Oh it’s quite tricky… :blush:
You will have to edit the theme files. I don’t have time to write a tutorial yet but something like this would help:
ok, thx…but without a clear “how to do” I will not be able to solve this problem…like I said before…I am a really beginner…greetings
Sure! Hopefully one can get done and it will help.
Keep in touch and please share your project when live!
@mufflern @yuzool
I think, I have a solution.
First, create a GIF with your pictures in a GIF builder.
Put this GIF in the resources.
Then copy this code in the site inspector CSS or global for all pages.
.content { background-image: url(%resource(123456.gif)%); background-repeat: no-repeat; background-position: center; -o-background-size: 100% 100%, auto; -moz-background-size: 100% 100%, auto; -webkit-background-size: 100% 100%, auto; background-size: 100% 100%, auto; }
Or simply this code.
.content { background-image: url(%resource(123456.gif)%); background-size: 100% 100%, auto; }
Look at my test site!
… and here.
Vielen Dank Oscar für die genauen Infos…Ich probiere das gleiche die Tage mal aus!!! DANKE!!!
@Oscar = Genius! :sunglasses:
@yuzool Thank you … my pleasure :wink:
