Stats gives a message:
Notice: A non well formed numeric value encountered in /private/var/folders/_b/5qmhghsn7t32x0dxf53hqxtr0000gn/T/com.realmacsoftware.rapidweaver8/RapidWeaver/41387/document-0x1187a1790/RWDocumentPagePreview/rw_common/plugins/stacks/statsAssets/admin.php on line 13
Have you an idea tio correct this?
Thank you i am going to join them.
Where are you seeing this error?:
Inside of Rapidweaver preview?
In a locally exported preview?
In the browser of a published page?
I am using Page safe with a 4 digits code to get access. Is it a problem?RB
Seems to be, as I can’t replicate the issue you’re seeing here.
Assuming you have the latest version of the Stats stack:
OK i have bought the last version and i am going to download it. Thank you for your patience
It seems to work with 1.06 Thank you very much!
