@differentdan Could PaySnap work for me as well do you think?
It seems the simplest option so far.
Bellow I see one unreadable msg from Yabdab developer flagged by the community. I see Paysnap in between the Addons store section. I guess what I would like to hear the most is - will RW continue to support PaySnap in future updates?
PaySnap should continue to work fine in RapidWeaver Classic with the Stacks 5 plugin so long as all those things are being developed/updated. It won’t work in RapidWeaver Elements unless @yabdab plans on porting it over.
Not sure if PaySnap would work for you. Mike over at @yabdab could advise if you contact him with your requirements.
Yes, plans for Paysnap 4 are in the works for Stacks 5 plugins ( and Stacks Pro app ).
I cannot promise anything about Elements since there has been little to no information given as to how we build add-ons for that platform.
Hope this helps ![]()
@yabdab - Does Paysnap 3 work with Stacks 5 as well?
Yes, it works with Stacks 5 and RW Classic.
