I’m the armadillo. Perhaps a duh ?, but using Header Pro, I don’t see the styling bar at the bottom the window to change the text color, nor another option in the inspectors.
In a STACKS3 tutorial, it was shown when the Header Pro was discussed.
Ideas?
Thanks,
Armi
Is that Big White Duck’s Header Pro? If so, you can change the colour in the settings.
Thsnk you for that, Rob!
