After moving all files to a folder from the desktop I can no longer save my project. Even if using a different name. I can exit RW (8) and reload document but still won’t let me save changes.
Solved it with the help of AAron from Realmac
Step 1 - create a new project file
Step 2 - copy/drag each page (1 by 1) to the new project
Step 3 - save after adding each pageIf you are able to move all pages over successfully, then perfect.
Step 4- Change your theme to the one you were using.
The old file name is still locked out from saving to but this procedure works for me.
