I am using RW 8.3 and Foundation themes. There is no problem about create page. But When I created the page and look at the view source for HTML code and SEO. There is problem about Turkish character.
Moreover My Site Language is Turkish.
If there are problems with the Turkish characters, it would suggest you are using a font which doesn’t have the full range of characters you need. Most modern fonts have these but you might be using a subset which does not.
