Uploading gets stuck on same file
Was just doing an quick change and publish and the project keeps getting stuck at the same spot, on a file called ‘structure.js’.
I’ve tried cancelling and re-publishing; republishing all files, and it’s still getting stuck.
I’m on a different network than I usually work on but that’s the only difference from my regular work flow.
RW 8.1.6; Stacks 3.6.6
