Who is able to help me with importing csv files to rapidcart pro?
I made a csv list to import to rapidcart pro, but it doesn’t upload, i don’t know why it doesn’t accept this file, the headers I changed them to the same lile rcpro. does anyone know how to make a correct list?
Seems that you have a CSV header which isn’t corresponding to the requirements. Should start on the left side with the column “productExportState”.
What you always can do is: have a few articles in the shop, then doing an export to a .csv file an then check the structure of the exported file. It’s best to load these csv files in Apple’s Numbers instead of Excel (as you already did I guess) because of the UTF-8 support. Then characters don’t get mixed-up :grinning:
