Hi all,
I am not able to resize the window inside of the preview for showing me the window size in RW8.
Is there another way for finding breakpoints for responsive layouts?
Thanks, Jochen
Hi all,
Thanks, Jochen
Does this help?
Not really. I have to find custom breakpoints. This was easy with RW7 and I do not see the actual width of the preview now, beside the pre-defined ones in the Device Preview.
Use the custom setting in the new window. You see the dimensions there
Thanks Jan. This works for me.
