Missing Polish characters in RW 7.1.1 [solved]
I was working on a project yesterday and all was fine. Today I wanted to continue my work but when I open the RW project file ALL my Polish characters like ś,ć, ń, ż, ł and others are missing. Instead some s*t appears. This was in RW 7.1. Now I updated to 7.1.1 and the issue remains. How am I supposed to continue my work? I guess even time machine backup will not help as 7.1 projects are not backwards compatible.
Yesterday all was fine, now I cannot work.
Please help. This is urgent.
Hi @koles,
Could you send us your project file so we can get it fixed for you. email support@realmacsoftware.com with a link to this thread.
Screenshots or how it looks now in 7.1.1 and how it’s supposed to look would also be helpful.
Thanks,
Dan
Since I am using Polish characters in my website, I would be very much interested in how this issue was solved. Thanks,
It turnout that Google analytics code in site wide header section caused the issue. Moving Google analytics code to body solved it.
Thanks a lot, Koleś.
