Rapidweaver Classic and Sitemap Plus from YourHead is missing?
Hi, I upgraded to the new version of Rapidweaver Classic - but the Sitemap Plus plugin from YourHead doesn’t work… it says: RapidWeaver failed to load some plugins. SiteMap… I have the latest version of the plugin.
Do you also have this problem? In the new version of RapidWeaver Classic all plugins should work.
Thanks.
Mike
EDIT:
Is it still the same problem with running RW under Rosseta… still? even after a year it’s not working.
Have you tried running it under Rosetta? That’s the fastest way to check.
I haven’t heard or seen anything on a native Apple M1 version from YourHead (@isaiah ) .
Last post I found
Hi, these stacks do open under Rosetta but that is sad really as it is just another overhead on performance.
Sitemap plus is actually a plugin, not a stack. As far as I know stacks (the plugin) works fine without Rosetta.
A agree it’s a shame that sitemap plus hasn’t been done in the universal build.
In March of 2021 (15 months ago) the status for the Universal build was listed as “ soon “.
Not sure what the timeline for this is now that YourHead is building a RapidWeaver competitive product.
We’ve pinged @isaiah here on RapidWeaver community, and as soon as we get a reply we’ll let you know!
Thank you, for your help!
Mike
Pinging @isaiah again to see if we can get an answer on this :crossed_fingers:
Update: We’ve heard back from @isaiah and he’s asking about what to work on next. Be sure to let him know as users Feedback always helps us developers out :+1:
Ok, thanks for the info. I wrote to the discussion.
Mike
Great stuff, fingers crossed :crossed_fingers:
On my M1 MacBook Pro I had to set RW to open using Rosetta.
You do this by right clicking on the RW app and then select “Open Using Rosetta”
After this step, I have not had any issues withe SiteMap Plus.
Screen Shot 2022-07-10 at 1.08.40 pm
